A new reconstruction method for 3D buildings from 2D vector floor plan
This paper proposes a method to analyze the geometry and semantic information of2D vector floor plans, and reconstruct the corresponding 3D building modelsautomatically. First, the Shape-opening graph (SOG) is introduced to recognizeStructural Components (SCs) and describe the relationships between SCs and openingswhich are architectural components separating spaces. A priority principle algorithmis developed to replace openings with wall equivalent lines for the purpose of laterloop searching. Then, we present an odd-even-based edge breaking algorithm topreprocess wall lines in order to search loops directly and exactly. After that, all theinterior-space contours, which are in fact rooms or aisles, and exterior boundarycontour can be obtained. With the hierarchical component tree presented, thetopological relations of the whole building can be obtained. Finally, 3D models can begenerated after extruding loops to the wall height and cutting openings from the walls.A drawing with several floor plans can also be reconstructed to multi-floor buildingafter aligning their dimensions. Moreover, the intermediate result after analyzing the2D floor plan can be the input of other architectural software to generate 3D models.
