Synchrony weakened by message adversaries vs asynchrony restricted by failure detectors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A message adversary is a daemon that suppresses messages in round-based message-passing synchronous systems in which no process crashes. A property imposed on a message adversary defines a subset of messages that cannot be eliminated by the adversary. It has recently been shown that when a message adversary is constrained by a property denoted TOUR (for tournament), the corresponding synchronous system and the asynchronous crash-prone read/write system have the same computability power for task solvability. This paper introduces new message adversary properties (denoted SOURCE and QUORUM), and shows that the synchronous round-based systems whose adversaries are constrained by these properties are characterizations of classical asynchronous crash-prone systems (1) in which processes communicate through atomic read/write registers or point-to-point message-passing, and (2) enriched with failure detectors such as Ω and Σ. Hence these properties characterize maximal adversaries, in the sense that they define strongest message adversaries equating classical asynchronous crash-prone systems. They consequently provide strong relations linking round-based synchrony weakened by message adversaries with asynchrony restricted with failure detectors. This not only enriches our understanding of the synchrony/asynchrony duality, but also allows for the establishment of a meaningful hierarchy of property-constrained message adversaries.
Cet article étudie les relations entre les modèles synchrones affaiblis par des adversaires supprimant des messages et les modèles asynchrones renforcés par des détecteurs de fautes.
Fichier non déposé
hal-00920734 , version 1 (19-12-2013)
Michel Raynal, Julien Stainer. Synchrony weakened by message adversaries vs asynchrony restricted by failure detectors. PODC, Jul 2013, Montréal, Canada. pp.166-175, ⟨10.1145/2484239.2484249⟩. ⟨hal-00920734⟩
179 Consultations
0 Téléchargements
