Non-simplifying Graph Rewriting Termination - Archive ouverte HAL Access content directly
Conference Papers Year : 2013
So far, a very large amount of work in Natural Language Processing (NLP) rely on trees as the core mathematical structure to represent linguistic informations (e.g. in Chomsky's work). However, some linguistic phenomena do not cope properly with trees. In a former paper, we showed the benefit of encoding linguistic structures by graphs and of using graph rewriting rules to compute on those structures. Justified by some linguistic considerations, graph rewriting is characterized by two features: first, there is no node creation along computations and second, there are non-local edge modifications. Under these hypotheses, we show that uniform termination is undecidable and that non-uniform termination is decidable. We describe two termination techniques based on weights and we give complexity bound on the derivation length for these rewriting systems.
termgraph.pdf (338.97 Ko) Télécharger le fichier
Dates and versions
hal-00921053 , version 1 (19-12-2013)
Identifiers
  • HAL Id : hal-00921053 , version 1
Cite
Guillaume Bonfante, Bruno Guillaume. Non-simplifying Graph Rewriting Termination. TERMGRAPH, Mar 2013, Rome, Italy. pp.4-16. ⟨hal-00921053⟩
199 View
152 Download
Share
