GeCoS: A framework for prototyping custom hardware design flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Antoine Floch
  • Fonction : Auteur
  • PersonId : 950174
Kevin Martin
GeCoS is an open source framework that provide a highly productive environment for hardware design. GeCoS primarily targets custom hardware design using High Level Synthesis, distinguishing itself from classical compiler infrastructures. Compiling for custom hardware makes use of domain specific semantics that are not considered by general purpose compilers. Finding the right balance between various performance criteria, such as area, speed, and accuracy, is the goal, contrary to the typical goal in high performance context to maximize speed. The GeCoS infrastructure facilitates the prototyping of hardware design flows, going beyond compiler analyses and transformations. Hardware designers must interact with the compiler for design space exploration, and it is important to be able to give instant feedback to the users.
Fichier non déposé
hal-00921370 , version 1 (20-12-2013)
Antoine Floch, Tomofumi Yuki, Ali El-Moussawi, Antoine Morvan, Kevin Martin, et al.. GeCoS: A framework for prototyping custom hardware design flows. 13th IEEE International Working Conference on Source Code Analysis and Manipulation (SCAM), Sep 2013, Eindhoven, Netherlands. pp.100-105, ⟨10.1109/SCAM.2013.6648190⟩. ⟨hal-00921370⟩
767 Consultations
0 Téléchargements
