A survey of schema-based matching approaches
Schema and ontology matching is a critical problem in many application domains, such as semantic web, schema/ontology integration, data warehouses, e-commerce, etc. Many different matching solutions have been proposed so far. In this paper we present a new classification of schema-based matching techniques that builds on the top of state of the art in both schema and ontology matching. Some innovations are in introducing new criteria which are based on (i) general properties of matching techniques, (ii) interpretation of input information, and (iii) the kind of input information. In particular, we distinguish between approximate and exact techniques at schema-level; and syntactic, semantic, and external techniques at element- and structure-level. Based on the classification proposed we overview some of the recent schema/ontology matching systems pointing which part of the solution space they cover. The proposed classification provides a common conceptual basis, and, hence, can be used for comparing different existing schema/ontology matching techniques and systems as well as for designing new ones, taking advantages of state of the art solutions.
Autre [cs.OH]
