A survey of schema-based matching approaches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal on Data Semantics Année : 2005
Schema and ontology matching is a critical problem in many application domains, such as semantic web, schema/ontology integration, data warehouses, e-commerce, etc. Many different matching solutions have been proposed so far. In this paper we present a new classification of schema-based matching techniques that builds on the top of state of the art in both schema and ontology matching. Some innovations are in introducing new criteria which are based on (i) general properties of matching techniques, (ii) interpretation of input information, and (iii) the kind of input information. In particular, we distinguish between approximate and exact techniques at schema-level; and syntactic, semantic, and external techniques at element- and structure-level. Based on the classification proposed we overview some of the recent schema/ontology matching systems pointing which part of the solution space they cover. The proposed classification provides a common conceptual basis, and, hence, can be used for comparing different existing schema/ontology matching techniques and systems as well as for designing new ones, taking advantages of state of the art solutions.
Autre [cs.OH]
shvaiko2005a.pdf (289.52 Ko) Télécharger le fichier
hal-00922287 , version 1 (25-12-2013)
Pavel Shvaiko, Jérôme Euzenat. A survey of schema-based matching approaches. Journal on Data Semantics, 2005, 4, pp.146-171. ⟨10.1007/11603412_5⟩. ⟨hal-00922287⟩
263 Consultations
964 Téléchargements
