Journal articles
A Formal Proof of Square Root and Division Elimination in Embedded Programs
Abstract : The use of real numbers in a program can introduce differences between the expected and the actual behavior of the program, due to the finite representation of these numbers. Therefore, one may want to define programs using real numbers such that this difference vanishes. This paper defines a program transformation for a certain class of programs that improves the accuracy of the computations on real number representations by removing the square root and division operations from the original program in order to enable exact computation with addition, multiplication and subtraction. This transformation is meant to be used on embedded systems, therefore the produced programs have to respect constraints relative to this kind of code. In order to ensure that the transformation is correct, i.e. preserves the semantics, we also aim at specifying and proving this transformation using the Pvs proof assistant.
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-00924367
Contributor : Pierre Neron Connect in order to contact the contributor
Submitted on : Monday, January 6, 2014 - 4:50:26 PM
Last modification on : Friday, January 21, 2022 - 3:15:38 AM
Long-term archiving on: : Thursday, April 10, 2014 - 5:25:26 PM
File
JFRarticle.pdf
Identifiers
  • HAL Id : hal-00924367, version 1
Collections
Citation
Pierre Neron. A Formal Proof of Square Root and Division Elimination in Embedded Programs. Journal of Formalized Reasoning, ASDD-AlmaDL, 2013, 6 (1), pp.89-111. ⟨hal-00924367⟩
Share
Metrics
Record views
108
Files downloads
129
