A Formal Proof of Square Root and Division Elimination in Embedded Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Formalized Reasoning Année : 2013
The use of real numbers in a program can introduce differences between the expected and the actual behavior of the program, due to the finite representation of these numbers. Therefore, one may want to define programs using real numbers such that this difference vanishes. This paper defines a program transformation for a certain class of programs that improves the accuracy of the computations on real number representations by removing the square root and division operations from the original program in order to enable exact computation with addition, multiplication and subtraction. This transformation is meant to be used on embedded systems, therefore the produced programs have to respect constraints relative to this kind of code. In order to ensure that the transformation is correct, i.e. preserves the semantics, we also aim at specifying and proving this transformation using the Pvs proof assistant.
JFRarticle.pdf (288.66 Ko) Télécharger le fichier
hal-00924367 , version 1 (06-01-2014)
  • HAL Id : hal-00924367 , version 1
Pierre Neron. A Formal Proof of Square Root and Division Elimination in Embedded Programs. Journal of Formalized Reasoning, 2013, 6 (1), pp.89-111. ⟨hal-00924367⟩
Collections
INRIA INRIA2
108 Consultations
155 Téléchargements
