Programming Robots With Events - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce how to use event-based style to program robots through the INI programming language. INI features both built-in and user-defined events, a mechanism to handle various kinds of changes happening in the environment. Event handlers run in parallel either synchronously or asynchronously, and events can be reconfigured at runtime to modify their behavior when needed. We apply INI to the humanoid robot called Nao, for which we develop an object tracking program.
iess2013.pdf (281.47 Ko) Télécharger le fichier
hal-00924489 , version 1 (07-01-2014)
Paternité
Truong Giang Le, Dmitriy Fedosov, Olivier Hermant, Matthieu Manceny, Renaud Pawlak, et al.. Programming Robots With Events. 4th International Embedded Systems Symposium (IESS), Jun 2013, Paderborn, Germany. pp.14-25, ⟨10.1007/978-3-642-38853-8_2⟩. ⟨hal-00924489⟩
588 Consultations
875 Téléchargements
