A Fast Algorithm for Well-Spaced Points and Approximate Delaunay Graphs - Archive ouverte HAL Access content directly
Conference Papers Year : 2013
Gary L. Miller
  • Function : Author
  • PersonId : 865086
Donald Sheehy
  • Function : Author
  • PersonId : 950510
Ameya Velingker
  • Function : Author
  • PersonId : 950511
We present a new algorithm that produces a well-spaced superset of points conforming to a given input set in any dimension with guaranteed optimal output size. We also provide an approximate Delaunay graph on the output points. Our algorithm runs in expected time $O(2^{O(d)}(n\log n + m))$, where $n$ is the input size, $m$ is the output point set size, and $d$ is the ambient dimension. The constants only depend on the desired element quality bounds. To gain this new efficiency, the algorithm approximately maintains the Voronoi diagram of the current set of points by storing a superset of the Delaunay neighbors of each point. By retaining quality of the Voronoi diagram and avoiding the storage of the full Voronoi diagram, a simple exponential dependence on $d$ is obtained in the running time. Thus, if one only wants the approximate neighbors structure of a refined Delaunay mesh conforming to a set of input points, the algorithm will return a size $2^{O(d)}m$ graph in $2^{O(d)}(n\log n + m)$ expected time. If $m$ is superlinear in $n$, then we can produce a hierarchically well-spaced superset of size $2^{O(d)}n$ in $2^{O(d)}n\log n$ expected time.
miller13fast.pdf (284.97 Ko) Télécharger le fichier
Dates and versions
hal-00924494 , version 1 (06-01-2014)
Identifiers
  • HAL Id : hal-00924494 , version 1
Cite
Gary L. Miller, Donald Sheehy, Ameya Velingker. A Fast Algorithm for Well-Spaced Points and Approximate Delaunay Graphs. ACM Symposium on Computational Geometry, 2013, Rio de Janeiro, Brazil. pp.289--298. ⟨hal-00924494⟩
Collections
INRIA INRIA2
108 View
237 Download
Share
