Conjoncture des processus d'indexation et de gestion des connaissances : vers la réindexaton par les usages.
The indexing process consists in the fact to describe content in a simple and manipulated index to make them usable in content for a given use form . The most common use is the information search by content. As example , a document is described by a structured sequence or keywords (or descriptors) , this sequence is the index of the document. When invoking the information retrieval (IR) process, we express a query as a sequence of descriptors borrowed the same or similar vocabulary indexing, and the RI system compares the query and index content to provide documents that coincide in whole or in part with the request. In the presentation of this problem , the contribution of the user who consults content while leaving traces of his actions, can capitalize on information and knowledge for the benefit of the reindexing process . This last point opens reflections research on the process of content management (see multimedia) by usage and therefore a review of the organization of knowledge between content, users and uses. In the context of the indexing of content by usage , it is necessary to consider developing a system of knowledge management to ensure: (i ) Filtering semantic concepts in content and the associated process for indexing ( ii) the organization of knowledge in queries to facilitate the process of information retrieval , (iii) the management of knowledge to meet the informational needs of the user, and (iv) the involvement of users associated with the variability of information needs for valuing content .
Le processus d'indexation consiste dans le fait de décrire des contenus dans une forme simple et manipulable pour rendre ces contenus exploitables pour un usage donné. L'usage le plus habituel est la recherche d'information par le contenu. En exemple, un document est décrit par une séquence structurée ou non de mots-clés (ou descripteurs) ; cette séquence constitue l'index du document. Quand on invoque le processus de recherche d'informations (RI), on exprime une requête sous la forme d'une séquence de descripteurs empruntés ou assimilés au même vocabulaire que l'indexation, puis le système RI compare la requête et l'index des contenus pour proposer les documents qui coïncident en tout ou en partie avec la requête. Dans l'exposé de cette problématique, l'apport de l'usager, qui consulte des contenus tout en laissant des traces sur ses actions, permet de capitaliser des informations et des connaissances au profit du processus de réindexation. Ce dernier point ouvrira des réflexions de recherche autour du processus de gestion des contenus (voir le multimédia) par les usages et donc un réexamen sur l'organisation des connaissances entre le contenu, l'usager et les usages. Dans le contexte de la réindexation de contenus par les usages, il est nécessaire de penser à mettre au point un système de management de la connaissance pour assurer : (i) le Filtrage de concepts sémantiques dans les contenus et le processus associé pour l'indexation, (ii) l'organisation des connaissances dans les requêtes pour faciliter le processus de recherche d'informations, (iii) la Gestion de connaissances pour réponde au besoin informationnel de l'usager, et (iv) l'implication des usagers associée à la variabilité des besoins informationnels pour la valorisation des contenus.
