Pretty-big-step-semantics-based Certified Abstract Interpretation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Martin Bodin
Thomas Jensen
  • Fonction : Auteur
  • PersonId : 874110
We present a technique for deriving semantic program analyses from a natural semantics specification of the programming language. The technique is based on the pretty-big-step semantics approach applied to a language with simple objects called O'While. We specify a series of instrumentations of the semantics that makes explicit the flows of values in a program. This leads to a semantics-based dependency analysis, at the core, e.g., of tainting analysis in software security. The formalization is currently being done with the Coq proof assistant.
essay.pdf (268.94 Ko) Télécharger le fichier
hal-00927400 , version 1 (13-01-2014)
  • HAL Id : hal-00927400 , version 1
Martin Bodin, Thomas Jensen, Alan Schmitt. Pretty-big-step-semantics-based Certified Abstract Interpretation. JFLA - 25ème Journées Francophones des Langages Applicatifs - 2014, Jan 2014, Fréjus, France. ⟨hal-00927400⟩
351 Consultations
261 Téléchargements
