IPv6 Routing and Autoconfiguration in Extended LANs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Martin Heusse
Andrzej Duda
We consider extended LANs composed of two different parts: a static one with hosts and routers, and a dynamic one with mobile hosts. We propose a scheme for interconnecting the two parts that builds on OLSR to establish compact routing tables, by aggregating addresses into prefixes whenever possible. Prefix advertisements imply possible conflicts of prefixes covering the same address ranges, thus we propose an extension to OLSR for solving this issue. We report on performance improvement measured on an experimental testbed.
Fichier non déposé
hal-00931046 , version 1 (06-02-2014)
Chi-Anh La, Martin Heusse, Michal Beno, Andrzej Duda. IPv6 Routing and Autoconfiguration in Extended LANs. ICC 2012 - IEEE International Conference on Communications, Jun 2012, Ottawa, ON, Canada. pp.2878-2883, ⟨10.1109/ICC.2012.6364083⟩. ⟨hal-00931046⟩
60 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
