Gathering and Exclusive Searching on Rings under Minimal Assumptions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Consider a set of mobile robots with minimal capabilities placed over distinct nodes of a discrete anonymous ring. Asynchronously, each robot takes a snapshot of the ring, determining which nodes are either occupied by robots or empty. Based on the observed configuration, it decides whether to move to one of its adjacent nodes or not. In the first case, it performs the computed move, eventually. The computation also depends on the required task. In this paper, we solve both the well-known Gathering and Exclusive Searching tasks. In the former problem, all robots must simultaneously occupy the same node, eventually. In the latter problem, the aim is to clear all edges of the graph. An edge is cleared if it is traversed by a robot or if both its endpoints are occupied. We consider the exclusive searching where it must be ensured that two robots never occupy the same node. Moreover, since the robots are oblivious, the clearing is perpetual, i.e., the ring is cleared infinitely often. In the literature, most contributions are restricted to a subset of initial configurations. Here, we design two different algorithms and provide a characterization of the initial configurations that permit the resolution of the problems under minimal assumptions.
ICDCN14_cameraReady.pdf (183.83 Ko) Télécharger le fichier
hal-00931514 , version 1 (15-01-2014)
Gianlorenzo d'Angelo, Alfredo Navarra, Nicolas Nisse. Gathering and Exclusive Searching on Rings under Minimal Assumptions. 15th International Conference on Distributed Computing and Networking (ICDCN), Jan 2014, Coimbatore, India. pp.149-164, ⟨10.1007/978-3-642-45249-9_10⟩. ⟨hal-00931514⟩
225 Consultations
282 Téléchargements
