Impact of Sampling-Source Extinction Ratio in Linear Optical Sampling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Photonics Technology Letters Année : 2013
We report on the impact of the sampling-source extinction ratio (ER) in a linear optical sampling system. To this effect, an analytical model is developed and contrasted with experimental data and numerical simulation, to determine the operational limits of the monitoring system. The ER of the reconstructed signal consists of a combined contribution from the magnitude of the symbol under test and the magnitude of the product between its neighboring symbols and the corresponding subpulses of the sampling source. The sampled signal can be completely reconstructed from its samples for ERs of the sampling source above 35 dB.
Impact_of_Sampling-Source_Extinction_Ratio_in_Linear_Optical_Sampling_PTL13.pdf (330.46 Ko) Télécharger le fichier
hal-00931661 , version 1 (15-01-2014)
Trung Hien Nguyen, Fausto Gomez Agis, Laurent Bramerie, Mathilde Gay, Jean-Claude Simon, et al.. Impact of Sampling-Source Extinction Ratio in Linear Optical Sampling. IEEE Photonics Technology Letters, 2013, 27 (7), pp.663-666. ⟨10.1109/LPT.2013.2248353⟩. ⟨hal-00931661⟩
692 Consultations
597 Téléchargements
