The walk on moving spheres: a new tool for simulating Brownian motion's exit time from a domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we introduce a new method for the simulation of the exit time and position of a $\delta$-dimensional Brownian motion from a domain. The main interest of our method is that it avoids splitting time schemes as well as inversion of complicated series. The idea is to use the connexion between the $\delta$-dimensional Bessel process and the $\delta$-dimensional Brownian motion thanks to an explicit Bessel hitting time distribution associated with a particular curved boundary. This allows to build a fast and accurate numerical scheme for approximating the hitting time. Numerical comparisons with existing methods are performed.
Revision-2-2013-Deaconu-et-al-2-HAL.pdf (181.29 Ko) Télécharger le fichier
hal-00931816 , version 1 (15-01-2014)
hal-00931816 , version 2 (16-10-2015)
Madalina Deaconu, Samuel Herrmann, Sylvain Maire. The walk on moving spheres: a new tool for simulating Brownian motion's exit time from a domain. 9th IMACS Seminar on Monte Carlo Methods (MCM), Jul 2013, Annecy le Vieux, France. pp.28-38, ⟨10.1016/j.matcom.2015.07.004⟩. ⟨hal-00931816v2⟩
501 Consultations
768 Téléchargements
