On the computation of the topology of plane curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Let P be a square free bivariate polynomial of degree at most d and with integer coefficients of bit size at most t. We give a deterministic algorithm for the computation of the topology of the real algebraic curve definit by P, i.e. a straight-line planar graph isotopic to the curve. Our main result is an algorithm for the computation of the local topology in a neighbourhood of each of the singular and critical points of the projection wrt the X axis in $\tilde{O} (d^6 t)$ bit operations where $\tilde{O}$ means that we ignore logarithmic factors in $d$ and $t$. Combined to state of the art sub-algorithms used for computing a Cylindrical Algebraic Decomposition, this result avoids a generic shear and gives a deterministic algorithm for the computation of the topology of the curve in $\tilde{O} (d^6 t + d^7)$ bit operations.
papier_DRR_long.pdf (321.48 Ko) Télécharger le fichier
hal-00935728 , version 1 (30-01-2014)
hal-00935728 , version 2 (20-05-2014)
  • HAL Id : hal-00935728 , version 1
Daouda Niang Diatta, Fabrice Rouillier, Marie-Françoise Roy. On the computation of the topology of plane curves. 2014. ⟨hal-00935728v1⟩
705 Consultations
350 Téléchargements
