Interference Networks With Point-to-Point Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 2011
The paper establishes the capacity region of the Gaussian interference channel with many transmitter-receiver pairs constrained to use point-to-point codes. The capacity region is shown to be strictly larger in general than the achievable rate regions when treating interference as noise, using successive interference cancellation decoding, and using joint decoding. In a spatial network where the nodes are distributed according to a Poisson point process and the channel path loss exponent is β >; 2, it is shown that the density of users that can be supported by treating interference as noise can scale no faster than B2/β as the bandwidth B grows, while the density of users can scale linearly with B under optimal decoding.
hal-00940548 , version 1 (01-02-2014)
François Baccelli, Abbas El Gamal, David Tse. Interference Networks With Point-to-Point Codes. IEEE Transactions on Information Theory, 2011, 57 (5), pp.2582-2596. ⟨10.1109/TIT.2011.2119230⟩. ⟨hal-00940548⟩
123 Consultations
0 Téléchargements
