Scale-invariant probabilistic latent component analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a new method to decompose musical spectrograms. This method transposes shift-invariant probabilistic latent component analysis (PLCA) which permits to decompose constant-Q spectrograms (with a logarithmic frequency resolution) to standard short-time Fourier transform spectrograms (with a linear frequency resolution). This makes it possible to easily use the method to reconstruct the latent signals (which can be useful for source separation).
articleWASPAA.pdf (345.04 Ko) Télécharger le fichier
hal-00945291 , version 1 (25-03-2014)
  • HAL Id : hal-00945291 , version 1
Romain Hennequin, Roland Badeau, Bertrand David. Scale-invariant probabilistic latent component analysis. Proc. of IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), 2011, New Paltz, New York, United States. pp.129--132. ⟨hal-00945291⟩
111 Consultations
193 Téléchargements
