Resolution of Linear Algebra for the Discrete Logarithm Problem Using GPU and Multi-core Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hamza Jeljeli
  • Fonction : Auteur
  • PersonId : 930510
In cryptanalysis, solving the discrete logarithm problem (DLP) is key to assessing the security of many public-key cryptosystems. The index-calculus methods, that attack the DLP in multiplicative subgroups of finite fields, require solving large sparse systems of linear equations modulo large primes. This article deals with how we can run this computation on GPU- and multi-core-based clusters, featuring InfiniBand networking. More specifically, we present the sparse linear algebra algorithms that are proposed in the literature, in particular the block Wiedemann algorithm. We discuss the parallelization of the central matrix--vector product operation from both algorithmic and practical points of view, and illustrate how our approach has contributed to the recent record-sized DLP computation in GF($2^{809}$).
linalg.pdf (542.55 Ko) Télécharger le fichier
hal-00946895 , version 1 (14-02-2014)
hal-00946895 , version 2 (04-12-2014)
hal-00946895 , version 3 (11-12-2014)
Hamza Jeljeli. Resolution of Linear Algebra for the Discrete Logarithm Problem Using GPU and Multi-core Architectures. Euro-Par 2014 Parallel Processing, Aug 2014, Porto, Portugal. ⟨hal-00946895v2⟩
535 Consultations
528 Téléchargements
