An Active Strategy for Plane Detection and Estimation with a Monocular Camera
Plane detection and estimation from visual data is a classical problem in robotic vision. In this work we propose a novel active strategy in which a monocular camera tries to determine whether a set of observed point features belongs to a common plane, and, if so, what are the associated plane parameters. The active component of the strategy imposes an optimized camera motion (as a function of the observed scene) able to maximize the convergence in estimating the scene structure. Based on this strategy, two methods are then proposed to solve the plane estimation task: a classical solution exploiting the homography constraint (and, thus, almost com- pletely based on image correspondances across distant frames), and an alternative method fully taking advantage of the scene structure estimated incrementally during the camera motion. The two methods are extensively compared in several case studies by discussing the various pros/cons.
Domains
Robotics [cs.RO]
