Incinerator - Eliminating Stale References in Dynamic OSGi Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
In the context of smart homes, the OSGi middleware is emerging as a standard to execute applications that collaborate together to render services. However, an application update in OSGi can introduce stale references, i.e., references to an outdated version of the application. A stale reference leads to a memory leak and to an inconsistency between the outdated version of the application and the new one. To avoid stale references, we propose Incinerator, a Java virtual machine extension that not only detects, but also eliminates stale references at runtime. Incinerator mainly runs when the garbage collector scans the object graph, so as to find stale references and set them to null. We have used Incinerator to detect a stale reference in the Knopflerfish OSGi framework implementation. Incinerator has a low overhead of at most 3.3% on average on the applications of the DaCapo benchmark suite. This shows that Incinerator is reasonable for use in production environments.
RR-8485.pdf (743.89 Ko) Télécharger le fichier
hal-00952327 , version 1 (26-02-2014)
  • HAL Id : hal-00952327 , version 1
Koutheir Attouchi, Gaël Thomas, André Bottaro, Julia L. Lawall, Gilles Muller. Incinerator - Eliminating Stale References in Dynamic OSGi Applications. [Research Report] RR-8485, Inria. 2014, pp.22. ⟨hal-00952327⟩
347 Consultations
376 Téléchargements
