A delay differential equation solver for MONOLIX & MLXPLORE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
We describe the implementation of a Delay differential Equation (DDE) solver in Monolix, a platform for population modeling of longitudinal data, and MlxPlore, a tool for the exploration of complex models. We use explicit Runge-Kutta schemes. Several examples for MlxPlore and Monolix are proposed.
RR-8489.pdf (539.49 Ko) Télécharger le fichier
hal-00952874 , version 1 (05-03-2014)
  • HAL Id : hal-00952874 , version 1
Raphaël Kuate, Marc Lavielle, Eric Blaudez, Kaelig Chatel, Jerome Marquet, et al.. A delay differential equation solver for MONOLIX & MLXPLORE. [Research Report] RR-8489, INRIA. 2014, pp.19. ⟨hal-00952874⟩
394 Consultations
1209 Téléchargements
