Routine-based Network Deployment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The careful deployment of hotspots in metropolitan areas allow to maximize WiFi offloading, a viable solution to the recent boost up of mobile data consumption. Our proposed strategy considers routine characteristics present on people's daily trajectories, the space-time interaction between them urban locations, and their transportation modes. Using a real-life metropolitan trace, we show our routine-based strategy guarantees higher offload ratio than the current approach in the literature while using a realistic traffic model.
conf.pdf (92.21 Ko) Télécharger le fichier
hal-00953700 , version 1 (28-02-2014)
  • HAL Id : hal-00953700 , version 1
Eduardo Mucelli Rezende Oliveira, Aline Carneiro Viana. Routine-based Network Deployment. INFOCOM Student Workshop, Apr 2014, Toronto, Canada. ⟨hal-00953700⟩
Collections
INRIA INRIA2
85 Consultations
143 Téléchargements
