Dynamic Learning of Indexing Concepts for Home Image Retrieval
This paper presents a component of a content based image retrieval system dedicated to let a user define the indexing terms used later during retrieval. A user inputs a indexing term name, image examples and counter-examples of the term,and the system learns a model of the concept as well as a similarity measure for this term. The similarity measure is based on weights reflecting the importance of each low-level feature extracted from the images. The system computes these weights using a genetic algorithm. Rating a particular similarity measure is done by clustering the examples and counter-examples using these weights and computing the quality of the obtained clusters. Experiments are conducted and results are presented on a set of 600 images.
Domains
Information Retrieval [cs.IR]
