New interface
Journal articles
Direct finite element computation of non-linear modal coupling coefficients for reduced-order shell models
Cyril Touzé 1 Marina Vidrascu 2 Dominique Chapelle 3
2 REO - Numerical simulation of biological flows
LJLL - Laboratoire Jacques-Louis Lions, Inria Paris-Rocquencourt, UPMC - Université Pierre et Marie Curie - Paris 6
3 M3DISIM - Mathematical and Mechanical Modeling with Data Interaction in Simulations for Medicine
LMS - Laboratoire de mécanique des solides, Inria Saclay - Ile de France
Abstract : We propose a direct method for computing modal coupling coefficients - due to geometrically nonlinear effects - for thin shells vibrating at large amplitude and discretized by a finite element (FE) procedure. These coupling coefficients arise when considering a discrete expansion of the unknown displacement onto the eigenmodes of the linear operator. The evolution problem is thus projected onto the eigenmodes basis and expressed as an assembly of oscillators with quadratic and cubic nonlinearities. The nonlinear coupling coefficients are directly derived from the finite element formulation, with specificities pertaining to the shell elements considered, namely, here elements of the ''Mixed Interpolation of Tensorial Components'' family (MITC). Therefore, the computation of coupling coefficients, combined with an adequate selection of the significant eigenmodes, allows the derivation of effective reduced-order models for computing - with a continuation procedure - the stable and unstable vibratory states of any vibrating shell, up to large amplitudes. The procedure is illustrated on a hyperbolic paraboloid panel. Bifurcation diagrams in free and forced vibrations are obtained. Comparisons with direct time simulations of the full FE model are given. Finally, the computed coefficients are used for a maximal reduction based on asymptotic nonlinear normal modes (NNMs), and we find that the most important part of the dynamics can be predicted with a single oscillator equation.
Complete list of metadata
Cited literature [50 references]  Display  Hide  Download
https://hal.inria.fr/hal-00955582
Contributor : Dominique Chapelle Connect in order to contact the contributor
Submitted on : Tuesday, March 4, 2014 - 5:29:03 PM
Last modification on : Tuesday, October 25, 2022 - 4:16:25 PM
Long-term archiving on: : Wednesday, June 4, 2014 - 12:10:48 PM
File
zedirectcomputation5R1.pdf
Identifiers
Citation
Cyril Touzé, Marina Vidrascu, Dominique Chapelle. Direct finite element computation of non-linear modal coupling coefficients for reduced-order shell models. Computational Mechanics, 2014, 54, pp.567-580. ⟨10.1007/s00466-014-1006-4⟩. ⟨hal-00955582⟩
Share
Metrics
Record views
757
Files downloads
459
