A direct bijective proof of the hook-length formula - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 1997
This paper presents a new proof of the hook-length formula, which computes the number of standard Young tableaux of a given shape. After recalling the basic definitions, we present two inverse algorithms giving the desired bijection. The next part of the paper presents the proof of the bijectivity of our construction. The paper concludes with some examples.
dm010104.pdf (175.1 Ko) Télécharger le fichier
hal-00955690 , version 1 (05-03-2014)
Jean-Christophe Novelli, Igor Pak, Alexander V. Stoyanovskii. A direct bijective proof of the hook-length formula. Discrete Mathematics and Theoretical Computer Science, 1997, Vol. 1, pp.53-67. ⟨10.46298/dmtcs.239⟩. ⟨hal-00955690⟩
199 Consultations
1328 Téléchargements
