Automated analysis of security protocols with global state - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
Security APIs, key servers and protocols that need to keep the status of transactions, require to maintain a global, non-monotonic state, e.g., in the form of a database or register. However, most existing automated verification tools do not support the analysis of such stateful security protocols - sometimes because of fundamental reasons, such as the encoding of the protocol as Horn clauses, which are inherently monotonic. A notable exception is the recent tamarin prover which allows specifying protocols as multiset rewrite (msr) rules, a formalism expressive enough to encode state. As multiset rewriting is a "low-level" specification language with no direct support for concurrent message passing, encoding protocols correctly is a difficult and error-prone process. We propose a process calculus which is a variant of the applied pi calculus with constructs for manipulation of a global state by processes running in parallel. We show that this language can be translated to msr rules whilst preserving all security properties expressible in a dedicated first-order logic for security properties. The translation has been implemented in a prototype tool which uses the tamarin prover as a backend. We apply the tool to several case studies among which a simplified fragment of PKCS#11, the Yubikey security token, and an optimistic contract signing protocol.
translation.pdf (713.47 Ko) Télécharger le fichier
hal-00955869 , version 1 (05-03-2014)
hal-00955869 , version 2 (12-05-2014)
Steve Kremer, Robert Künnemann. Automated analysis of security protocols with global state. [Research Report] arXiv. 2014, pp.56. ⟨hal-00955869v2⟩
255 Consultations
1106 Téléchargements
