Numerical methods for one-dimensional aggregation equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
We focus in this work on the numerical discretization of the one dimensional aggregation equation $\pa_t\rho + \pa_x (v\rho)=0$, $v=a(W'*\rho)$, in the attractive case. Finite time blow up of smooth initial data occurs for potential $W$ having a Lipschitz singularity at the origin. A numerical discretization is proposed for which the convergence towards duality solutions of the aggregation equation is proved. It relies on a careful choice of the discretized macroscopic velocity $v$ in order to give a sense to the product $v \rho$. Moreover, using the same idea, we propose an asymptotic preserving scheme for a kinetic system in hyperbolic scaling converging towards the aggregation equation in hydrodynamical limit. Finally numerical simulations are provided to illustrate the results.
num1D_v5.pdf (4.88 Mo) Télécharger le fichier
hal-00955971 , version 1 (05-03-2014)
hal-00955971 , version 2 (29-10-2014)
Francois James, Nicolas Vauchelet. Numerical methods for one-dimensional aggregation equations. 2014. ⟨hal-00955971v1⟩
576 Consultations
341 Téléchargements
