SOUR graphs for efficient completion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 1998
We introduce a data structure called \emphSOUR graphs and present an efficient Knuth-Bendix completion procedure based on it. \emphSOUR graphs allow for a maximal structure sharing of terms in rewriting systems. The term representation is a dag representation, except that edges are labelled with equational constraints and variable renamings. The rewrite rules correspond to rewrite edges, the unification problems to unification edges. The Critical Pair and Simplification inferences are recognized as patterns in the graph and are performed as local graph transformations. Our algorithm avoids duplicating term structure while performing inferences, which causes exponential behavior in the standard procedure. This approach gives a basis to design other completion algorithms, such as goal-oriented completion, concurrent completion and group completion procedures.
dm020101.pdf (274.73 Ko) Télécharger le fichier
hal-00958899 , version 1 (13-03-2014)
Christopher Lynch, Polina Strogova. SOUR graphs for efficient completion. Discrete Mathematics and Theoretical Computer Science, 1998, Vol. 2, pp.1-25. ⟨10.46298/dmtcs.247⟩. ⟨hal-00958899⟩
170 Consultations
803 Téléchargements
