Sums of Digits, Overlaps, and Palindromes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2000
Let s_k(n) denote the sum of the digits in the base-k representation of n. In a celebrated paper, Thue showed that the infinite word (s_2(n) \bmod 2)_n≥ 0 is \emphoverlap-free, i.e., contains no subword of the form axaxa where x is any finite word and a is a single symbol. Let k,m be integers with k>2, m≥ 1. In this paper, generalizing Thue's result, we prove that the infinite word t_k,m := (s_k(n) \bmod m)_n≥ 0 is overlap-free if and only if m≥ k. We also prove that t_k,m contains arbitrarily long squares (i.e., subwords of the form xx where x is nonempty), and contains arbitrarily long palindromes if and only if m≤ 2.
dm040101.pdf (141.27 Ko) Télécharger le fichier
hal-00958941 , version 1 (13-03-2014)
Jean-Paul Allouche, Jeffrey Shallit. Sums of Digits, Overlaps, and Palindromes. Discrete Mathematics and Theoretical Computer Science, 2000, Vol. 4 no. 1 (1), pp.1-10. ⟨10.46298/dmtcs.282⟩. ⟨hal-00958941⟩
104 Consultations
968 Téléchargements
