A survey of multivariate aspects of the contraction method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2006
We survey multivariate limit theorems in the framework of the contraction method for recursive sequences as arising in the analysis of algorithms, random trees or branching processes. We compare and improve various general conditions under which limit laws can be obtained, state related open problems and give applications to the analysis of algorithms and branching recurrences.
449-1674-1-PB.pdf (250.04 Ko) Télécharger le fichier
hal-00961114 , version 1 (20-03-2014)
Ralph Neininger, Ludger Rüschendorf. A survey of multivariate aspects of the contraction method. Discrete Mathematics and Theoretical Computer Science, 2006, Vol. 8, pp.31--56. ⟨10.46298/dmtcs.369⟩. ⟨hal-00961114⟩
Collections
TDS-MACS
67 Consultations
867 Téléchargements
