Entity Resolution in the Web of Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This tutorial provides an overview of the key research results in the area of entity resolution that are relevant to addressing the new challenges in entity resolution posed by the Web of data, in which real world entities are described by interlinked data rather than documents. Since such descriptions are usually partial, overlapping and sometimes evolving, entity resolution emerges as a central problem both to increase dataset linking but also to search the Web of data for entities and their relations.
tutorial.pdf (47.07 Ko) Télécharger le fichier
hal-00962165 , version 1 (20-03-2014)
  • HAL Id : hal-00962165 , version 1
Kostas Stefanidis, Vasilis Efthymiou, Melanie Herschel, Vassilis Christophides. Entity Resolution in the Web of Data. International World Wide Web Conference (WWW), Apr 2014, Seoul, South Korea. ⟨hal-00962165⟩
3127 Consultations
993 Téléchargements
