Early Nested Word Automata for XPath Query Answering on XML Streams - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2015
Denis Debarbieux
  • Fonction : Auteur
  • PersonId : 909306
Joachim Niehren
Tom Sebastian
  • Fonction : Auteur
  • PersonId : 964487
Algorithms for answering XPath queries on Xml streams have been studied intensively in the last decade. Nevertheless, there still exists no solution with high efficiency and large coverage. In this paper, we introduce early nested word automata in order to approximate earliest query answering algorithms for nested word automata. Our early query answering algorithm is based on stack-and-state sharing for running early nested word automata on all answer candidates with on-the-fly determinization. We prove tight upper complexity bounds on time and space consumption. We have implemented our algorithm in the QuiXPath system and show that it outperforms all previous tools in coverage on the XPathMark benchmark, while obtaining very high time and space efficiency and scaling to huge Xml streams. Furthermore, it turns out that our early query answering algorithm is earliest in practice on most queries from the XPathMark benchmark.
1-23.pdf (746.72 Ko) Télécharger le fichier
hal-00966625 , version 1 (20-02-2015)
Denis Debarbieux, Olivier Gauwin, Joachim Niehren, Tom Sebastian, Mohamed Zergaoui. Early Nested Word Automata for XPath Query Answering on XML Streams. Theoretical Computer Science, 2015, 578, pp.100-125. ⟨10.1016/j.tcs.2015.01.017⟩. ⟨hal-00966625⟩
362 Consultations
449 Téléchargements
