A note on improvement of adaptive observer robustness - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper the problem of adaptive observer design in the presence of disturbances is studied, and an augmented adaptive observer is proposed. First, the $H_{\infty}$ gain of a conventional adaptive observer is estimated, which characterizes the effect of disturbances on output errors. Next, it is shown that if the disturbance is ''matched'' in the plant equations, then it is possible to introduce additional sliding-mode feedback, dependent on the plant output, improving the accuracy of observation. Simulation results confirm the improvement.
Sliding_adaptive_observer_.pdf (222.89 Ko) Télécharger le fichier
hal-00967893 , version 1 (31-03-2014)
  • HAL Id : hal-00967893 , version 1
Denis Efimov, Christopher Edwards, Ali Zolghadri. A note on improvement of adaptive observer robustness. 19th IFAC World Congress, Aug 2014, Cape Town, South Africa. ⟨hal-00967893⟩
326 Consultations
291 Téléchargements
