Hypersingular integral equations over a disc: convergence of a spectral method and connection with Tranter's method
Two-dimensional hypersingular equations over a disc are considered. A spectral method is developed, using Fourier series in the azimuthal direction and orthogonal polynomials in the radial direction. The method is proved to be convergent. Then, Tranter's method is discussed. This method was devised in the 1950s to solve certain pairs of dual integral equations. It is shown that this method is also convergent because it leads to the same algebraic system as the spectral method.
