New interface
Conference papers
Collaborative Virtual Environments for Ergonomics: Embedding the Design Engineer Role in the Loop
Charles Pontonnier 1 Thierry Duval 2 Georges Dumont 1
1 MIMETIC - Analysis-Synthesis Approach for Virtual Human Simulation
UR2 - Université de Rennes 2, Inria Rennes – Bretagne Atlantique , IRISA-D6 - MEDIA ET INTERACTIONS
2 Hybrid - 3D interaction with virtual environments using body and mind
Abstract : The aim of this paper is to define the role and duties of a design engineer involved in a collaborative ergonomic design session supported by a 3D collaborative virtual environment. For example, such a session can be used to adapt the manual task an operator must achieve in the context of an industrial assembly line. We first present the interest of such collaborative sessions. Then we present a related work explaining the need of proper 3DCVE and metaphors to obtain efficient collaborative ergonomic design sessions. Then, after a short definition of the role of the engineer in such sessions, we propose a use case highlighting the type of metaphor such engineers need to have to be efficient in such a framework. Discussion and future works ends the paper.
Document type :
Conference papers
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/hal-00974020
Contributor : Thierry Duval Connect in order to contact the contributor
Submitted on : Friday, April 4, 2014 - 9:18:27 PM
Last modification on : Monday, June 27, 2022 - 3:07:23 AM
Long-term archiving on: : Friday, July 4, 2014 - 2:12:13 PM
File
CVE3D_duval_et_al_DRAFT.pdf
Identifiers
  • HAL Id : hal-00974020, version 1
Citation
Charles Pontonnier, Thierry Duval, Georges Dumont. Collaborative Virtual Environments for Ergonomics: Embedding the Design Engineer Role in the Loop. 2014 International Workshop on Collaborative Virtual Environments (3DCVE), IEEE VR, Mar 2014, Minneapolis, United States. ⟨hal-00974020⟩
Share
Metrics
Record views
532
Files downloads
363
