Structure of the orthorhombic Al13Co4(100) surface using LEED, STM and ab initio studies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review B: Condensed Matter and Materials Physics (1998-2015) Année : 2011
In a combined scanning tunneling microscopy (STM), low-energy electron diffraction (LEED), and density functional theory (DFT) study of the surface of Al13Co4(100), all techniques have found that after annealing to 1165 K, the surface structure is consistent with a dense Al-rich plane with surface Co atom depletion. Various structure models were considered, and in the LEED study, the best agreement was found with a model that consists of Al-rich terminating planes with no Co atoms, and otherwise a structure similar to the bulk puckered layers. This structure was also found to be stable in the DFT study. The best-fit structural parameters are presented for the two domains of this structure, which contain bipentagons that can be related to the pentagonal bipyramidal structures in the bulk, plus additional glue atoms between them. These domains are not strictly related to each other by symmetry, as they have different surface relaxations. The STM study found significant differences in the surfaces of samples grown by different methods and is able to explain a different interpretation made in an earlier study.
PhysRevB.84.085411.pdf (718.52 Ko) Télécharger le fichier
hal-00974224 , version 1 (07-04-2014)
Heekeun Shin, Katariina Pussi, Emilie Gaudry, Julian Ledieu, Vincent Fournée, et al.. Structure of the orthorhombic Al13Co4(100) surface using LEED, STM and ab initio studies. Physical Review B: Condensed Matter and Materials Physics (1998-2015), 2011, 84 (8), pp.085411. ⟨10.1103/PhysRevB.84.085411⟩. ⟨hal-00974224⟩
131 Consultations
321 Téléchargements
