LigRE: Reverse-Engineering of Control and Data Flow Models for Black-Box XSS Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fuzz testing consists of automatically generating and sending malicious inputs to an application in order to hopefully trigger a vulnerability. In order to be efficient, the fuzzing should answer questions such as: Where to send a malicious value? Where to observe its effects? How to position the system in such states? Answering such questions is a matter of understanding precisely enough the application. Reverse- engineering is a possible way to gain this knowledge, especially in a black-box harness. In fact, given the complexity of modern web applications, automated black-box scanners alternatively reverse- engineer and fuzz web applications to detect vulnerabilities. We present an approach, named as LigRE, which improves the reverse engineering to guide the fuzzing. We adapt a method to automatically learn a control flow model of web applications, and annotate this model with inferred data flows. Afterwards, we generate slices of the model for guiding the scope of a fuzzer. Empirical experiments show that LigRE increases detection capabilities of Cross Site Scripting (XSS), a particular case of web command injection vulnerabilities.
Informatique
Fichier non déposé
hal-00974762 , version 1 (07-04-2014)
  • HAL Id : hal-00974762 , version 1
Fabien Duchene, Sanjay Rawat, Jean-Luc Richier, Roland Groz. LigRE: Reverse-Engineering of Control and Data Flow Models for Black-Box XSS Detection. Working Conference in Reverse Engineering (WCRE 2013), 2013, Koblenz-Landau, Germany. pp.252-261. ⟨hal-00974762⟩
133 Consultations
0 Téléchargements
