Understanding Anisotropic Highlights for Interactive Appearance Editing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2013
This poster introduces a system for the direct editing of highlights produced by anisotropic BRDFs, which we call anisotropic highlights. We first provide a comprehensive analysis of the link between the direction of anisotropy and the shape of highlight curves for arbitrary object surfaces. The gained insights provide the required ingredients to infer BRDF orientations from a prescribed highlight tangent field. This amounts to a non-linear optimization problem, which is solved at interactive framerates during manipulation. Taking inspiration from sculpting software, we provide tools that give the impression of manipulating highlight curves while actually modifying their tangents. Our solver produces desired highlight shapes for a host of lighting environments and anisotropic BRDFs.
Prism_v2.pdf (775 Ko) Télécharger le fichier
Format : Figure, Image
hal-00976697 , version 1 (16-04-2014)
  • HAL Id : hal-00976697 , version 1
Boris Raymond, Pascal Barla, Romain Pacanowski, Xavier Granier. Understanding Anisotropic Highlights for Interactive Appearance Editing. PRISM2: The science of light & shade, Oct 2013, Bordeaux, France. 2013. ⟨hal-00976697⟩
355 Consultations
200 Téléchargements
