Cooperation in a swarm of robots using RFID landmarks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Paul Couderc
  • Fonction : Auteur
  • PersonId : 833468
Michel Banâtre
  • Fonction : Auteur
  • PersonId : 833460
Roberto Beraldi
  • Fonction : Auteur
  • PersonId : 868990
In a world that is giving prominence to ubiquitous computing, a classical standalone robot, though as complex, specialised and efficient as it may be, is not suitable for a distributed environment. The aim is to have knowledge and computing power diffused in the environment, exploiting the collaboration of simple, flexible and cost-effective robots. Collective intelligence increases when each one communicates basic information about its local state, to update the global knowledge. An open research problem is the cooperation among multiple entities in a distributed environment. Our proposal is to have robots with low capabilities that can learn information and instructions from on-site RFID landmarks to place themselves in formation, synchronise with other robots in the area, and finally carry out a cooperative task.
Fichier non déposé
hal-00977207 , version 1 (10-04-2014)
Giulio Zecca, Paul Couderc, Michel Banâtre, Roberto Beraldi. Cooperation in a swarm of robots using RFID landmarks. Robotic and Sensors Environments, 2008. ROSE 2008. International Workshop, University of Ottawa, Oct 2008, Ottawa, Ontario, Canada. ⟨10.1109/ROSE.2008.4669171⟩. ⟨hal-00977207⟩
198 Consultations
0 Téléchargements
