Preprints, Working Papers, ...
Sessions with an unbounded number of agents
Abstract : In web-based business systems, agents engage in structured interactions, called sessions. Sessions are logical units of computations, like transactions. However, unlike transactions, sessions cannot be isolated from each other. Thus, one has to verify such systems in the presence of both intended and unintended interference between sessions. The main challenge in building a tractable model of sessions is that there is no a priori bound on the number of concurrently active agents and sessions in the system. Realistic specifications require agents to compare entities across sessions, but this has to be modelled without assigning an unbounded set of unique identities to active agents and sessions. We propose a model called session systems that allows for an arbitrary number of concurrently active agents and sessions. Agents are equipped with a limited ability to remember partners across sessions. Configurations are represented as graphs and the operational semantics is described through graph-rewriting. We show that, under reasonable restrictions, session systems are well-structured systems. This provides an effective verification algorithm for simple coverability properties. We then show how to use this result to verify more elaborate business rules such as avoidance of conflicts of interest and the Chinese Wall Property.
Document type :
Complete list of metadata
Cited literature [20 references]  Display  Hide  Download
https://hal.inria.fr/hal-00979409
Contributor : Loic Helouet Connect in order to contact the contributor
Submitted on : Wednesday, April 23, 2014 - 10:56:59 PM
Last modification on : Thursday, January 20, 2022 - 4:20:23 PM
Long-term archiving on: : Wednesday, July 23, 2014 - 1:30:10 PM
File
SessionsACSD.pdf
Identifiers
  • HAL Id : hal-00979409, version 2
Citation
Sundararaman Akshay, Loïc Hélouët, Madhavan Mukund. Sessions with an unbounded number of agents. 2014. ⟨hal-00979409v2⟩
Share
Metrics
Record views
264
Files downloads
192
