Accelerated Approximation of the Complex Roots of a Univariate Polynomial (Extended Abstract) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Highly efficient and even nearly optimal algorithms have been developed for the classical problem of univariate polynomial root-finding (see, e.g., \cite{P95}, \cite{P02}, \cite{MNP13}, and the bibliography therein), but this is still an area of active research. By combining some powerful techniques developed in this area we devise new nearly optimal algorithms, whose substantial merit is their simplicity, important for the implementation.
pt-cr-snc.pdf (127.57 Ko) Télécharger le fichier
hal-00980584 , version 1 (18-04-2014)
Victor Y. Pan, Elias Tsigaridas. Accelerated Approximation of the Complex Roots of a Univariate Polynomial (Extended Abstract). SNC '14 - Symposium on Symbolic-Numeric Computation, Jul 2014, Shanghai, China. pp.132-134, ⟨10.1145/2631948.2631973⟩. ⟨hal-00980584⟩
230 Consultations
214 Téléchargements
