Derivatives of approximate regular expressions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2013
Our aim is to construct a finite automaton recognizing the set of words that are at a bounded distance from some word of a given regular language. We define new regular operators, the similarity operators, based on a generalization of the notion of distance and we introduce the family of regular expressions extended to similarity operators, that we call AREs (Approximate Regular Expressions). We set formulae to compute the Brzozowski derivatives and the Antimirov derivatives of an ARE, which allows us to give a solution to the ARE membership problem and to provide the construction of two recognizers for the language denoted by an ARE. As far as we know, the family of approximative regular expressions is introduced for the first time in this paper. Classical approximate regular expression matching algorithms are approximate matching algorithms on regular expressions. Our approach is rather to process an exact matching on approximate regular expressions.
2194-8170-1-PB.pdf (266.55 Ko) Télécharger le fichier
hal-00980761 , version 1 (18-04-2014)
Jean-Marc Champarnaud, Hadrien Jeanne, Ludovic Mignot. Derivatives of approximate regular expressions. Discrete Mathematics and Theoretical Computer Science, 2013, Vol. 15 no. 2 (2), pp.95--120. ⟨10.46298/dmtcs.598⟩. ⟨hal-00980761⟩
124 Consultations
983 Téléchargements
