Topology Construction in RPL Networks over Beacon-Enabled 802.15.4 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Malisa Vucinic
Connectez-vous pour contacter l'auteur
Gabriele Romaniello
  • Fonction : Auteur
Laurene Guelorget
  • Fonction : Auteur
Bernard Tourancheau
Franck Rousseau
Olivier Alphand
Andrzej Duda
Laurent Damon
  • Fonction : Auteur
In this paper, we propose a new scheme that allows coupling beacon-enabled IEEE 802.15.4 with the RPL routing protocol while keeping full compliance with both standards. We provide a means for RPL to pass the routing information to Layer 2 before the 802.15.4 topology is created by encapsulating RPL DIO messages in beacon frames. The scheme takes advantage of 802.15.4 command frames to solicit RPL DIO messages. The effect of the command frames is to reset the Trickle timer that governs sending DIO messages. We provide a detailed analysis of the overhead incurred by the proposed scheme to understand topology construction costs. We have evaluated the scheme using Contiki and the instruction-level Cooja simulator and compared our results against the most common scheme used for dissemination of the upper-layer information in beacon-enabled PANs. The results show energy savings during the topology construction phase and in the steady state.
rpl-topologyconstruction-camera-ready.pdf (360.58 Ko) Télécharger le fichier
hal-00985933 , version 1 (30-04-2014)
hal-00985933 , version 2 (18-12-2014)
Malisa Vucinic, Gabriele Romaniello, Laurene Guelorget, Bernard Tourancheau, Franck Rousseau, et al.. Topology Construction in RPL Networks over Beacon-Enabled 802.15.4. Computers and Communication (ISCC), 2014 IEEE Symposium on, Jun 2014, Madeira, Portugal. ⟨10.1109/ISCC.2014.6912563⟩. ⟨hal-00985933v2⟩
1499 Consultations
512 Téléchargements
