Spectral Bandits for Smooth Graph Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Michal Valko
Rémi Munos
  • Fonction : Auteur
  • PersonId : 836863
Tomáš Kocák
  • Fonction : Auteur
  • PersonId : 955512
Smooth functions on graphs have wide applications in manifold and semi-supervised learning. In this paper, we study a bandit problem where the payoffs of arms are smooth on a graph. This framework is suitable for solving online learning problems that involve graphs, such as content-based recommendation. In this problem, each item we can recommend is a node and its expected rating is similar to its neighbors. The goal is to recommend items that have high expected ratings. We aim for the algorithms where the cumulative regret with respect to the optimal policy would not scale poorly with the number of nodes. In particular, we introduce the notion of an effective dimension, which is small in real-world graphs, and propose two algorithms for solving our problem that scale linearly and sublinearly in this dimension. Our experiments on real-world content recommendation problem show that a good estimator of user preferences for thousands of items can be learned from just tens of nodes evaluations.
valko2014spectral.pdf (448.63 Ko) Télécharger le fichier
hal-00986818 , version 1 (05-05-2014)
hal-00986818 , version 2 (16-05-2014)
hal-00986818 , version 3 (20-05-2014)
  • HAL Id : hal-00986818 , version 1
Michal Valko, Rémi Munos, Branislav Kveton, Tomáš Kocák. Spectral Bandits for Smooth Graph Functions. 31th International Conference on Machine Learning, Jun 2014, Beijing, China. ⟨hal-00986818v1⟩
519 Consultations
556 Téléchargements
