Linear Time Recognition Algorithms and Structure Theorems for Bipartite Tolerance Graphs and Bipartite Probe Interval Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2010
A graph is a probe interval graph if its vertices can be partitioned into probes and nonprobes with an interval associated to each vertex so that vertices are adjacent if and only if their corresponding intervals intersect and at least one of them is a probe. A graph G = (V, E) is a tolerance graph if each vertex v is an element of V can be associated to an interval I(v) of the real line and a positive real number t(v) such that uv is an element of E if and only if vertical bar I(u) boolean AND I(v)vertical bar >= min \t(u), t(v)\. In this paper we present O(vertical bar V vertical bar + vertical bar E vertical bar) recognition algorithms for both bipartite probe interval graphs and bipartite tolerance graphs. We also give a new structural characterization for each class which follows from the algorithms.
1327-5746-1-PB.pdf (449.62 Ko) Télécharger le fichier
hal-00990447 , version 1 (13-05-2014)
David E. Brown, Arthur H. Busch, Garth Isaak. Linear Time Recognition Algorithms and Structure Theorems for Bipartite Tolerance Graphs and Bipartite Probe Interval Graphs. Discrete Mathematics and Theoretical Computer Science, 2010, Vol. 12 no. 5 (5), pp.63-82. ⟨10.46298/dmtcs.494⟩. ⟨hal-00990447⟩
Collections
TDS-MACS
36 Consultations
1089 Téléchargements
