Tiling Periodicity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2010
Tiling Periodicity
We contribute to combinatorics and algorithmics of words by introducing new types of periodicities in words. A tiling period of a word w is partial word u such that w can be decomposed into several disjoint parallel copies of u, e.g. a lozenge b is a tiling period of a a b b. We investigate properties of tiling periodicities and design an algorithm working in O(n log (n) log log (n)) time which finds a tiling period of minimal size, the number of such minimal periods and their compact representation. The combinatorics of tiling periods differs significantly from that for classical full periods, for example unlike the classical case the same word can have many different primitive tiling periods. We consider also a related new type of periods called in the paper multi-periods. As a side product of the paper we solve an open problem posted by T. Harju (2003).
1352-5055-1-PB.pdf (201.11 Ko) Télécharger le fichier
hal-00990466 , version 1 (13-05-2014)
Juhani Karhumaki, Yury Lifshits, Wojciech Rytter. Tiling Periodicity. Discrete Mathematics and Theoretical Computer Science, 2010, Vol. 12 no. 2 (2), pp.237-248. ⟨10.46298/dmtcs.517⟩. ⟨hal-00990466⟩
Collections
TDS-MACS
35 Consultations
659 Téléchargements
