Bisimulations up-to: beyond first-order transition systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The bisimulation proof method can be enhanced by employing 'bisimulations up-to' techniques. A comprehensive theory of such enhancements has been developed for first-order (i.e., CCS-like) labelled transition systems (LTSs) and bisimilarity, based on the notion of compatible function for fixed-point theory. We transport this theory onto languages whose bisimilarity and LTS go beyond those of first-order models. The approach consists in exhibiting fully abstract translations of the more sophisticated LTSs and bisimilarities onto the first-order ones. This allows us to reuse directly the large corpus of up-to techniques that are available on first-order LTSs. The only ingredient that has to be manually supplied is the compatibility of basic up-to techniques that are specific to the new languages. We investigate the method on the pi-calculus, the lambda-calculus, and a (call-by-value) lambda-calculus with references.
fo.pdf (259.84 Ko) Télécharger le fichier
hal-00990859 , version 1 (14-05-2014)
Jean-Marie Madiot, Damien Pous, Davide Sangiorgi. Bisimulations up-to: beyond first-order transition systems. CONCUR, Sep 2014, Rome, Italy. ⟨10.1007/978-3-662-44584-6_8⟩. ⟨hal-00990859⟩
388 Consultations
741 Téléchargements
