Composite left/right-handed stacked hole arrays at sub-millimeter wavelength - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Physics Année : 2010
High-transmissivity composite left/right-handed uniaxial bulk metamaterials were fabricated in a multilayered dielectric/hole metal array technology and experimentally assessed at submillimeter wavelengths (0.4–0.9 THz) by time-domain spectroscopy. From the frequency dependence of the complex scattering parameters, we show the possibility to close the gap between the left- and right-handed dispersion branches by increasing the number of layers from 3 to 5. Such a demonstration paves the way of balance composite propagation characteristics with a gapless transition between the negative and positive values of refractive index at a frequency of 0.5 THz.
Lippens_1.3374703_JAP_2010.pdf (791.34 Ko) Télécharger le fichier
hal-00991480 , version 1 (27-07-2021)
  • HAL Id : hal-00991480 , version 1
Shengxiang Wang, Frédéric Garet, Karine Blary, Charles Croënne, Eric Lheurette, et al.. Composite left/right-handed stacked hole arrays at sub-millimeter wavelength. Journal of Applied Physics, 2010, 107, pp.074510. ⟨hal-00991480⟩
196 Consultations
17 Téléchargements
